Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 08-19-2005, 10:21 AM   #1
Aqua Angel
Aqua Angel's Avatar
Aqua Angel Normal reputation
Send a message via ICQ to Aqua Angel Send a message via AIM to Aqua Angel Send a message via MSN to Aqua Angel Send a message via Yahoo to Aqua Angel
Question Cruise Control Switch
Hello guys
i have a big problem. I am taking a new steering column today as my original one failed or should say really broke while i was driving. meaning that i could no longer signal, shifter arm is gone and hearing some weird noise in the shaft while i turn.
i found a steering column that has no Cruise sontrol on it, but the guy at the junk yard said that i could put one in or remove the one i have and put it in. she has a tilt, Cruise, well fully loaded and i am hoping to have some instruction from you guys to figure out how to remove that switch and how to put it in the new location?
what type of tool is required in order to do such a thing.
thanks
Luv Angel
93, Chevy Astro van, Saphire Blue, Led tail light.
looking for:
Euro clear corner lights and Billet grill "chrome" and a good shinny 5 spoke rims and a disc brake rear differential
Aqua Angel is offline   Reply With Quote
Old 08-19-2005, 07:46 PM   #2
CD Smalley
CD Smalley Normal reputation
Re: Cruise Control Switch
Well it's pretty complicated...
You need to pull the turn signal/cruise control stalk out. You have to pull hard though.
Then you clip the wires going to it as close as possible. Now, tape the wires from the new stalk to the old wires. Next find the where the wires come out of the column under the dash. Unplug it and pull the new wires thru, gently.
CD Smalley
1991 W41 #142
1995 Astro
1989 Caprice 9C1
1997 C1500
1977-90 GM B-Body email list Owner @ yahoogroups.com
In the recovery room: b-body.org...
CD Smalley is offline   Reply With Quote
Old 08-19-2005, 09:49 PM   #3
Aqua Angel
Aqua Angel's Avatar
Re: Re: Cruise Control Switch
Thanks for the tip. the only problem is ... I have my other steering column. the thing is, my other one doesn't have a cruise control switch. so i will have to wigle that darn wire a few time until i can see it from the other side then tape it then connect it then do the Diff then power steering pump then then then ... then rebuild the engine. Poor van over 550,000.00 KM she is a tough one
looking for:
Old 08-19-2005, 09:52 PM   #4
CD Smalley
You could snake some safety wire down the column and then use that to pull the cruise control wire though.
CD Smalley
1991 W41 #142
1995 Astro
1989 Caprice 9C1
1997 C1500
Old 08-19-2005, 10:01 PM   #5
Aqua Angel
Aqua Angel's Avatar
will do just that.
Cheers
looking for:
Old 08-24-2005, 08:59 PM   #6
Aqua Angel
Aqua Angel's Avatar
Got it installed on both my steering column and switches and it works like a charm. 2 1/2 years driving this van and my lever never came back once i was done turning "signal lever" i mean. Steering is so much better now. drives like a charm.
looking for:
Bookmarks
Google
Web AF
