3ed gen 3SGTE into 2end gen mr2
Google
Web AF
ZerO281eCHo
08-18-2005, 06:19 PM
Hi, I might be buying a 1991 mr2 shell, and i was thinking about puting a third generation motor in it, is that possible?
ghetto7o2azn
08-18-2005, 11:42 PM
yeah.. people do it all the time.. but it might be easier to just find a nicely conditioned mr2 turbo and start from there
ZerO281eCHo
08-18-2005, 11:53 PM
do u know if it needs any welding of any sort, or does is it just drop in, cause i cant afford an mr2 right now, so imam buy a shell, and pay it off, and then the motor, and pay that off, then have it put in for the spring
ac427cpe
08-19-2005, 02:37 AM
the engine drops in, but the wiring won't be fun.
JekylandHyde
08-19-2005, 07:14 AM
Under no circumstances would I ever recommend going to a Gen III.
That being said, you will need a lot more than just the engine. You will need the wiring harness and ECU as well. If your "shell" was from the NA MR2, you are going to need a transmission, axles and gauge cluster as well.
ZerO281eCHo
08-19-2005, 12:44 PM
so, yall saying to stick with a the second gen motor.
JekylandHyde
08-19-2005, 02:12 PM
Yes.
Google
Web AF
