1991 4X$ Toyota Pickup hard to start when warm
pierre2005
08-17-2005, 11:19 PM
Truck takes a very long time to start when warm, cold starts are OK and if I turn it off when hot and start it back up right away, all is fine. The problem is only when it sits for a few minutes after warming up. the engine cranks and cranks and finally starts up. This seem to be hard on the battery and starter, any help would be appreciated.
Fuel pump bracket has been changed and gas leaks from the tank when it is close to full, otherwise truck is running fine, no "check engine light"...
Any ideas...
Pierre
Zresare
08-18-2005, 04:18 PM
My 1993 toyota pickup with a 22re has done that ever since I've owned it and I've always wanted to fix it. I just got my fuel injectors rebuilt to help fix a misfire, with no fix. Let me know if anyone finds a solution. Some people have said ignition, because everything else on my truck is in working order. and I haven't tested the ignition.
KimMG
08-19-2005, 01:34 AM
Check all the vacuum lines?
