1996 Monte Dash & Tail Lightsjmorrell 08-17-2005, 10:57 PM The light that illuminates the speedometer, odometer and tachometer (sp) does not work. Also, I do not have either tail light right now. Is it a fuse located on the passenger's side panel or one under the hood? Is it a short? Are they connected to each other or two seperate problems? Help me please. fist 08-18-2005, 04:10 AM Turn signal switch might be worn (probley not) Start with checking the fuse panel under the hood on the driver side, might have corrosion shorting it out!! Does anything else not work? hazzzmattt 08-18-2005, 04:26 AM really sounds like you need to start at the dimmer/headlight switch. jmorrell 08-18-2005, 09:13 AM The brake lights, reverse lights, cigarette lighter, dome light, chime, radio, glove compartment light, reading lights on rearview, and headlights work. Sometimes, the left turn signal won't work but if you wiggle the turn signal thing on the steering column it will work again. How do you replace the dimmer switch and would that effect the taillights? fist 08-22-2005, 08:21 AM Turn signal switch! With what you said about the turn signal needing to be wiggled that is where I would try! dsa87gn 08-23-2005, 07:28 PM i had this problem and wasted cash on the dimmer switch.. turned out to be the fuse under the hood on the drivers side see this link http://www.automotiveforums.com/vbulletin/showthread.php?p=2239042#post2239042 Automotive Network, Inc., Copyright ©2012
