GearBox OilAWD Primera 07-25-2001, 12:37 AM My gearbox has a very slow oil leak. My Mechanic said not to bother fixing it as it would be very expensive. He said to just keep it topped up. I was wondering if anybody knows how to top up your gearbox oil? What type of Oil is best? How much oil does a gearbox normally take? Can I top it up myself or does it need to go on a hoist? PS Its a Manual Transmission. Blue93G20 07-26-2001, 06:54 AM My 93.5 G20 took just shy of 4 qts. of redline MTL 90wt. gear oil. To do this you have to get under the vehicle then use a 1/2 inch drive to undo the drain plug for the transmission fluid to drain. The refill point is located on the front of the transmission facing the front of the car. I believe the refill plug is a 3/4 drive. not sure. I had to buy a $6 pump from autozone to pump the fluid back into the transmission this also had to be done from under the car. I hope that helps. Ohh yeah MTL smells horrible don't get it on your skin. AWD Primera 07-27-2001, 12:24 AM Cheers for the info. I shall give it a go Automotive Network, Inc., Copyright ©2012
