Butane/Gasoline 1991 Trooper
common_sense
08-17-2005, 09:42 PM
Hi:
It may sound a bit crazy but I converted my 1991 Trooper to use Butane or Gasoline (only 1 type is used at a time, I use a switch). I normally run it on Butane because its about 50% cheaper and have been doing so for more than an year. I haven't seen any mention of something similar on the forum and I would appreciate if someone knowledgeable on the subject can give me a hand with my problem or can direct me to a site that may have something relevant.
Problem: When the engine is cold, it takes two tries (cranks) to start the engine. It doesn't do it if the engine is hot or if I start the engine 15 to 20 minutes after having shut down the engine.
The reason why I ask is because my father-in-law has a trooper that is the same year and make as mine but its engine starts on the first try.
Specs: 2.6 L, 4 Cyl, manual transmission
Would really appreciate any suggestions.
awer25
08-19-2005, 09:01 PM
My guess is that the butane has trouble igniting inside a cold combustion chamber (ie cold engine). Next time its running, switch to gas about a minute before you turn it off and see if that helps. Either way 2 cranks is not bad at all.
BTW, how much work (and $) was the butane conversion? I've also heard of people converting their engines to steam power, which can burn old crankcase oil (should be free from a garage). Interesting ideas now that gas costs as much as milk!
common_sense
08-19-2005, 10:22 PM
It costs about $750 US dollars. That includes labor, tank, and other accessories required. All of these takes about half a day to be done.
JesseJamesMcGuire
09-04-2005, 11:38 PM
Could you please tell me or show me where you got this product from Common Ihave the same trooper as you. Plus I am poor, and dont' wanna buy gas.
common_sense
09-10-2005, 12:44 PM
Jesse, I'll get you the information as soon as possible.
