Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-17-2005, 12:59 PM   #1
mrtwo
mrtwo Normal reputation
How to take the starter out?
I have a 96 Corolla and recently it hesitates to start. Can anyone share an idea how to take it out? I heard the repair is pretty simple. But it seems very difficult to take the starter out. A mechanic told me he would charge two hours of labor for that since the starter is behind the engine.
mrtwo is offline   Reply With Quote
Old 08-17-2005, 01:37 PM   #2
deadring
deadring Normal reputation
Re: How to take the starter out?
first time took me about 30- 45 min to take out.. the second time ( i bought a bad one) took 15-20 min.
unplug the battery en bolt the son of a... it's pretty easy to do
Deadring
89' corolla ...200 000 miles on original engine, tranny,clutch and paint...and no rust... try that with a neon...
00' kawasaki zx-9 with micron exaust and K&N filter ( my baby)
deadring is offline   Reply With Quote
Old 08-17-2005, 03:47 PM   #3
mrtwo
Did work above or under the car? I can hardly see it from above. Do you need any special tools? Thanks.
Old 08-18-2005, 08:07 AM   #4
deadring
you do it from above, but you have to lean on the engine,( btw the engine being cold helps ALOT) and you need a ratchet with 13 mm, 12mm, 10mm, an d maybe 14 or 17 i dunno. and some other maybe smaller in order to remove the bolt that holds the cable on the starter.
it looks harder than it really is man don't worry, but you weill be blind when you do it.. you won't be able to see much.. you have to rely on your sens of touch. the first time is the tougher
hope this helps
Deadring
Old 08-18-2005, 11:49 AM   #5
mrtwo
Thanks, Deadring. That helps alot.
Old 08-18-2005, 03:53 PM   #6
johnholl
johnholl Normal reputation
Re: Re: How to take the starter out?
Is the starter on the front side on the 96 or on the firewall side?
johnholl is offline   Reply With Quote
Old 08-18-2005, 04:01 PM   #7
deadring
firewall side
Old 08-22-2005, 07:55 PM   #8
mrtwo
deadring,
Which year is your Corolla? I just took a look at the starter. I feel even I can somehow unscrew it, there is not enough space to take it out from above.
Old 08-23-2005, 07:52 AM   #9
deadring
mines an 89, but my last one was a 91 with EFI and the only way to take it out was, after all the cables where off it, to yank it out... turn it on itself a couple times till you find a "right" way to pull it up.
well first of all this is gonna take about an hour of your time, just unhook every cable off it( AFTER you unplug the battery of course) and unscrew it.. you'll see what i mean,
like i said before, it looks harder than it really is.. i too, had hesitation in doing it.
Good luck
Deadring
Old 08-23-2005, 09:41 AM   #10
bcopeland
bcopeland Normal reputation
No sir. On my 91 you do have to disconnect a lot of stuff. But you stand over the top of the car facing the windshild and take the screws out. Then you can tilt it out from the passenger side near the power sterring pump.
bcopeland is offline   Reply With Quote
Old 09-05-2005, 09:05 AM   #11
womparing
womparing Normal reputation
Deadring
I think the starter just went on my 1989 seca had a horrible whinning sound ... will only stop once battery is disconnected.
Do I need a new starter motor or is there somethng else that can be done? Hope you can help.
womparing is offline   Reply With Quote
Old 09-05-2005, 09:12 AM   #12
womparing
my car just started a high pitch whinning sound and wont switch off unless battery disconnected. I assume it is starter motor. does it need to be replaced or is there something else to do? Cheers
Old 09-05-2005, 10:35 AM   #13
bcopeland
Sounds like the ABS motor is bad. That is the only thing I know that whines until you disconnect the battery. Check out this site - http://www.modulemaster.com/
Old 09-05-2005, 04:26 PM   #14
womparing
thanks we are having a look at it today. fingers crossed.
Old 09-21-2005, 11:56 AM   #15
mrtwo
Just want to let your guys know I have my starter replaced at Strauss for $170 and it is a new one.
Bookmarks
Google
Web AF
