08-17-2005, 06:41 AM
22" Dvinci Havoc XL Wheels Question
I am looking to get these wheels, can anyone let me know if they will fit my '05 TB EXT 4WD?
22" Dvinci Havoc XL
Hankook 265/35/22
And what do those #'s mean for the tire? I assume the last one is for the 22" wheels.
08-17-2005, 08:37 AM
You need to look at the lug placement... usually will look like 6x127 or 6x5.0 (this is our lug placement)
Also you need to check on offset -> You don't want the wheels sticking out of the wheel well.
(265) Tire Width
The 265 is the width of the tire in millimeters (mm), measured from sidewall to sidewall. Since this measure is affected by the width of the rim, the measurement is for the tire when it is on its intended rim size.
(35) Aspect Ratio
This number tells you the height of the tire, from the bead to the top of the tread. This is described as a percentage of the tire width. In our example, the aspect ratio is 35, so the tire's height is 35 percent of its width, or 92.75 mm ( .35 x 265 = 92.75 mm). The smaller the aspect ratio, the wider the tire in relation to its height.
High performance tires usually have a lower aspect ratio than other tires. This is because tires with a lower aspect ratio provide better lateral stability. When a car goes around a turn lateral forces are generated and the tire must resist these forces. Tires with a lower profile have shorter, stiffer sidewalls so they resist cornering forces better.
(22) Rim Diameter
This number specifies, in inches, the wheel rim diameter the tire is designed for.
2004 Trailblazer LT
08-17-2005, 09:46 AM
Re: 22" Dvinci Havoc XL Wheels Question
thanks a lot man.
well i would assume the lug placement is the same since i am buying them off a guy with an 03 TB.
let me know if i am assuming incorrectly
but i am unsure about the offset.
whats that about?
would it be the same from an 03 TB to what should be on my 05?
thanks?
http://www.cardomain.com/ride/2034806
08-17-2005, 10:20 AM
Re: Re: 22
Originally Posted by dh4645
thanks a lot man.
whats that about?
thanks?
Yes it should be.... sent you a PM
2004 Trailblazer LT
08-17-2005, 10:30 AM
i signed up, thanks.
thanks for the help too
08-23-2005, 04:21 PM
Re: Re: 22
Congrats for the wheels. I hope they are great. Could you post a pic if possible.
Well, I dont know if its true or not, I heard here in Kuwait that 22" really screws up your transmission gear so most of them recommend 20". Any suggestions???
08-24-2005, 06:46 AM
here's what they look like.
i have never heard anything about them messing up the transmission and plenty of people have 22's
anyone else hear of this.
08-24-2005, 11:57 AM
Re: Re: Re: 22
Dude who ever said that must have been on a good crack pipe or something because thats just a bunch of B.S. any way if anything it might give you worse gas milage depending on how much bigger the wheels & tires are compared to the stock one then again you might not even notice it at all.
08-24-2005, 12:51 PM
Re: Re: Re: Re: 22
Well, I thought the same but wanted to be double sure before I place the order as I am getting them all the way from US to Kuwait. And the shipping will be killing me  Thanks guys
08-24-2005, 01:16 PM
man i feel you on the S&H i just got a new dash for another truck i have and the S&H was 3 times more than what i paid for the dash man S&H is outrages nowdays
08-24-2005, 01:51 PM
all because of those F'ing gas prices
08-24-2005, 06:35 PM
so if you dont mind me asking what where the damages for does sweet wheels (cost including tires)
08-26-2005, 09:35 AM
here are my new wheels/tires.
just put em on last night.
they are actually 285/35/22 tires
i bought em off a guy on cardomain.com (seanope)
he had them for like 3 months, but his lease was up on the TB amd he was gonna get an H3.
Brand new they would have been about $3,200
I got them for $1,800....very good deal.
08-26-2005, 11:15 AM
man i feel you on does wheels they look great verry verry cool and that price man that was steal did that include S&H even if S&H was say 200 thats still a great price
08-26-2005, 11:30 AM
no S&H
sean paid for it...not that he did a good job, but there was no damage to the wheels.
the guy i got em from works for MTV and also does advertising/sales for PLUSH magazine...he could afford it. haha
