95 cavalier, signals aren't flashingCassie Leanne 08-15-2005, 10:03 PM My turn signals aren't flashing. They turn on, but they don't flash. What bulbs do I need to replace? jakegday 08-16-2005, 04:50 PM the ones that are dead..... if both your right and left blinkers dont blink though, its probably the flasher itself, the thing that makes the actual clicking noise, i THINK it would be in your fusebox, if that $3 piece doesnt fix it its probably your switch, i had a switch go bad in my 86 plymouth reliant, for that old of a car the piece was $120 at an auto parts store, deadBird 08-16-2005, 11:08 PM Yeah, replace the blubs first... they're cheap. Cassie Leanne 08-17-2005, 09:08 PM thanks :) Coupons420 08-19-2005, 04:33 AM probaly just a fuse if its blown it will just go on and not blink or blink eraticaly in the car but do nothing outside gmack221 08-19-2005, 02:49 PM replace the flasher, had the same thing go wrong with my 95 grand am, but I spent the time to tear apart the column thinking it was the switch, good thing I tried the cheap flasher before the switch. the flasher should be located under the dash by the pedals. Mine had a nice little door to open to get to it. Pretty simple buy the new one so you know what it looks like, then look for it. **there may be 2 on your car (there was mine) one runs the turn signals, one runs the 4-way-flashers. if your 4-ways work turn them on so you can hear the one that works clicking, then change the other one. Its pretty rare that all 4 bulbs go out at once. 95cavspeed 08-19-2005, 09:05 PM hey i have a 95 cav when i got it same problem it wasnt bulbs it was flasher and just so u know its not located in the fuse box its under the stearing wheel by the stearing colum itself and replce that problm solved Automotive Network, Inc., Copyright ©2012
