Gears?skidmark 05-03-2002, 01:30 PM Can someone please explain. If your gears are higher, what happens? If your gears are lower what happens? thanks everybody. BlkCamaroSS 05-03-2002, 06:01 PM I believe it's the higher the gears, the better the acceleration, and less streetability. 4.10's are good for dragging down the quarter mile, but are not suited for stop and go traffic. If you're looking for a good compromise between stock 3.23's and 4.10's, 3.73's are a good way to go. Depends on your car's use... (note: I believe this is how it goes, I'm going on what I think I remember, if I'm wrong, chime in) Blackbird01 05-07-2002, 09:18 PM The 'gears' you're referring to are located in the rear differential. If you lower the gear numerically, you increase the overall size of the gear. In example a 2.73 gear is smaller numerically then a 4.10, but bigger in physical SIZE. The smaller the gear is NUMERICALLY, the higher your theoretical topspeed is but slower your acceleration is. It's just the opposite for a bigger numerically, gear. Most LS1 6-speed owners chose 4.10 gears. I've been in a 6spd. LS1 eqpt. with them and around town it's perfectly fine. In fact, better then the stock 3.42's. On the highway, revs are kept very low with the 6th gear. From a stop, the car pulls like a MADMAN! Most LS1 A4 owners swap to 3.73s or stick with the "optional" 3.23s that come factory. I've still got the 3.23's in my car, but I'm sure I'll throw a 3.73 out back when I get a new rearend. The stocker's on borrowed time. (knock on wood) jester151315 10-08-2007, 05:29 PM to add more....fuel economy = 3.23 big burn out = 4.56........you looking for economy or show, its up to you and only you........ reason for this simply.....your engine revs higher..... ex. 2000RPM with 3.23 at 60MPH 3200RPM with 4.10 at 60MPH izzydjinn 10-08-2007, 06:40 PM using skidmarks thread, if you have a v6 3.8 manual whats the best way to go. blindeyed 10-08-2007, 09:16 PM OLD THREAD!! jester, please check the dates of threads before you post in them, this one is over 5 years old! Automotive Network, Inc., Copyright ©2012
