1995 Ford Escort Taillights
Spiffy62004
08-15-2005, 07:47 PM
I have a 1995 Ford Escort wagon that I am trying to sell but have run into a problem with it. The taillights will not light up when the lights are turned on. The breaks, hazzards, turn signals, and reverse lights all work fine. I have replaced the fuses and the bulbs in both and have no idea where to go with it now, I have a buyer for it and he will only buy it if I can get it fixed :-/ .....can anyone please help me?
escortgt
08-15-2005, 09:56 PM
try cleaning the contacts on the inside of the socket, sometimes they get gummed up and won't make contact.
KimMG
08-16-2005, 01:13 AM
Are the dash lights working?
Are you geting power to the light sockets? If yes, then check the ground connection(s).
AzTumbleweed
08-16-2005, 08:10 AM
Do the side marker lights work? If so, splice into them for lights :smile:
chevyn0va1
08-16-2005, 08:19 AM
Yes you could also conferm they are the right bulbs and that if they are correct that they are not blown. Like if its a two stage light make sure both filiments are good.
AzTumbleweed
08-16-2005, 09:22 AM
Make sure it is the right bulb. There is another bulb that looks the same but won't work. The correct bulb I believe is 1157 or 3157. The 1156 and 3156 look the same but don't work.
Escort_Service
08-19-2005, 01:16 AM
Look for your grounds, there the usual problem. If they get loose and its a hot day the coating that the factory puts on will get between your contact and the wire causing it not to work. From what I understand it is a single ground point for rear assembaly in the 95.
Also this might me a long shot, but I had feul pump problems cause of the ground point I picked for my sub. If you have a stero try moving the ground point. The tail lights will use less voltage then a system will and can sometimes interfear with other ground points.
