transmission clunks into third
Google
Web AF
gillers29
08-15-2005, 01:32 PM
99 Envoy with 74k. It has a clunk when shifting into 3rd. All other gears shift smooth. The lower the throttle the louder the clunk. No codes. 5k ago, I changed the fluid and filter with no improvement. It's been doing this for a while. Runs fine otherwise, the clunk is just annoying. Any suggestions?
gillers29
08-25-2005, 02:41 PM
Anyone have any idea as to why it will shift hard from 2-3? It does it warm or cold. Maybe the clunk is just my u-joints. I haven't changed those, but if the tranny is shifting hard at 2-3, wouldn't it just wear out new u-joints? Any thoughts?
blazes9395
08-26-2005, 01:03 AM
First you have to make sure its either your u-joints, or your tranny. In my opinion, if its just the 2-3 shift, it probably is not your u-joints(but check). If it is the tranny(most likely), GM used plastic accumulator pistons in these transmissions. These plastic pistons have been known to break, or crack, causing a malfunction, or, in your case, poor shifting. In your case, its most likly the 2-3 piston that is cracked or broken, causing a bad 2-3 shift. To get to the 2-3, the valve body has to come off, and the piston is at the bottom right. Rebuilders usually replace these pistons with aluminum pistons(as the earlier models had), eliminating the chances of a broken plastic piston.
gillers29
09-15-2005, 10:15 AM
Thanks for the info blazes. Anyone know where I could purchase a 2-3 acuumulator piston? All I see on rockauto is a rebuild kit with 1-2 and 3-4 pistons.
Google
Web AF
