MR2 Swapkcfan 08-14-2005, 04:32 PM ok i am thinking about engine swaping but i dont no if it will fit into my 1992 paseo so can any 1 help me out? MR2 Turbo MK2 3S-GTE 90-93 - Engine, 5-Speed Transmission, Computer Specifications DOHC 4cyl. 16val. 2.0L Turbo • Year: 90-93 • HP: 220hp@6000rpm • Torque: 200lbs@3000rpm • Diplacement: 1998cc • Compression Ratio: 8.8:1 List Of Parts Included • Complete Motor - Block - Head - Intake Manifold - Exhaust Manifold - Sensors - Fuel Rail - Injectors - Cam Angle Sensor - Throttle Body - Alternator - Starter - Ignition Wires - Pulleys - Turbo manifold - Turbocharger • 5-Speed Transmission • Computer(ECU) • Cut Wiring Harness * Complete wiring harness availabe for extra $100.00, you must call to verify availability. Aslo if there is another engine i can swap plz tell me. also a link on where i can buy it at. veilside686 11-06-2005, 08:30 PM not sure but probably not. even if it was a little easy you would be seeing threads about it all over. But u dont. ebrokersunlimited 12-09-2005, 01:33 AM not sure but probably not. even if it was a little easy you would be seeing threads about it all over. But u dont. The 20valve 4age fwd setups will work.. have seen a few over the years,, I have a AE101 Levin front clip with this engine,, I was looking at a Paseo a few months ago to buy to do this swap, but just dotn have the time.. you can email me at partsfreak@yahoo.com I'll send you some pics.. thanks and good luck.. Automotive Network, Inc., Copyright ©2012
