Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon
Old 08-14-2005, 02:04 PM   #1
imcnblu
imcnblu Normal reputation
Exclamation cant get crank pulley off of 95 neon need help ASAP!!!!!
i'm putting a new timing belt and water pump on a 95 dodge neon with a 2.0 SOHC motor, every thing was coming out smoothly until i got to the crank pulley, i removed the bolt in the center of it and couldn't get it off, i used a 3 fingered pulley puller and i ended up breakin the damn thing. anyway, if someone could help me out in gettin this thing off because its 2:00pm, and i've been messing with the pulley since 10:30 this morning. help needed as soon as possible, CAR MUST BE RUNNING BY TOMORROW!
imcnblu is offline   Reply With Quote
Old 08-14-2005, 02:09 PM   #2
TEXSRT4
TEXSRT4 Normal reputation
Re: cant get crank pulley off of 95 neon need help ASAP!!!!!
i used a 3 finger puller and an air gun! you might have to go buy a stronger unit!
TEXSRT4 is offline   Reply With Quote
Old 08-14-2005, 02:13 PM   #3
imcnblu
yeah, the sad part was it was a loner from autozone, and now i gotta pay for it, i used an airgun and it broke the head of the bolt. now, when you took yours out, was it as much of a pain in the ass as mine, cuz i've been at it with prybars, pullers etc. since 10:30 this morning.
Old 08-14-2005, 04:07 PM   #4
maykelcj
maykelcj's Avatar
maykelcj Normal reputation
I used the big autozone puler; however, I used a braker-bar instead of an airgun. The airgun rotates too fast and you have little control of what's going on.It's a pain in the ass, but it is what worked for me.
12:1 all motor neon, sold
got me a CRX HF and put a DOHC ZC on it.
maykelcj is offline   Reply With Quote
Old 08-14-2005, 05:23 PM   #5
das2123
Tuning Neons since '97
das2123's Avatar
das2123 Normal reputation
Send a message via AIM to das2123 Send a message via Yahoo to das2123
This should help you out.
http://forums.neons.org/viewtopic.php?t=121498
das2123 is offline   Reply With Quote
Old 08-14-2005, 07:27 PM   #6
TEXSRT4
you think getting it off is hard...wait til you put it on!!!! hahaha it sucked
Old 08-15-2005, 05:29 AM   #7
maykelcj
maykelcj's Avatar
Re: Re: cant get crank pulley off of 95 neon need help ASAP!!!!!
Originally Posted by das2123
Great article!!!
Old 08-15-2005, 09:49 AM   #8
das2123
das2123's Avatar
I guess I was lucky, mine slipped right on after I heated it up to 400 degrees for 20 minutes
Old 08-15-2005, 10:02 PM   #9
TEXSRT4
that requires time, it was way late, and i needed to get going. we just knocked it on, and used an air gun to tighten it. not the right thing to do, but i was tired and didnt want to deal with it. besides its hard to heat somthing up without access to an oven or source of flame...though we did have a cigarette lighter. i wonder how long that would have taken?
Old 10-03-2005, 12:33 AM   #10
ebailiff
ebailiff Normal reputation
95 Dodge Neon crank pulley
The car I'm working on is a '97 Dodge Neon.I first tried a loaner from AutoZone for
Chrysler dampers and soaked the damper with PB Blaster overnight; broke one of the finger tips off using an airgun. Then tried a 5 ton 3-jaw puller from Autozone, broke the damper. Since I don't have a torch, I called a mobile mechanic who had the exact same experience before and had to cut through it with a torch. He did this with mine, it melted the lower part of the timing cover and left marks on the crankshaft snout. I used a fine stone with a die grinder to remove the raised marks. Plan on using antiseize paste and maybe heating the new damper to install it. OTC Tools sells the correct removal and installation tools for this model. It's a specail 3-jaw puller with a long rod that installs in the puller and is inserted into the crank snout. It's not the same as the ones from Autozone. Can order from Pep Boy's. More on this after I try installing the damper.
ebailiff is offline   Reply With Quote
Old 10-09-2005, 01:10 PM   #11
maykelcj
maykelcj's Avatar
Re: 95 Dodge Neon crank pulley
get now a UDP it will fit better.
Old 10-09-2005, 03:56 PM   #12
idriveacab
idriveacab Normal reputation
i broke my first 3 jaw puller(one of the teeth) so i went to sears and bought a craftsman, with this one it gives you two differnt lengths of arms. i used a socket with ratchet and mine popped off with some pressure,but the craftsman didnt break
idriveacab is offline   Reply With Quote
Old 10-09-2005, 10:38 PM   #13
ebailiff
Re: Re: 95 Dodge Neon crank pulley
What is a "UDP"?
Old 10-09-2005, 10:46 PM   #14
ebailiff
As I said in my first post, after breaking the first Chrysler specialty puller, I rented a standard 5 ton 3-jaw puller and the damper itself broke, not the puller. OTC Tools (www.otctools.com) makes a special 3 jaw puller that is made to fit these dampers perfectly and an installer.
Old 10-10-2005, 12:26 AM   #15
skatendestroy
skatendestroy Normal reputation
Send a message via AIM to skatendestroy
hmmmmmmm mine wasnt as hard as it was my mistake itself was using a wo jawed puller and breaking the dampner by putting the arms on the outside edging of the pulley so i ended up buying a three jaw puller and go to the junk yard and pulling a dampener off another neon and then pullling it off it was a load of fun i must say....
skatendestroy is offline   Reply With Quote
Bookmarks
Google
Web AF
