93 pickup with antifreeze in the oilFD5 08-13-2005, 02:56 PM I am thinking a head gasket? Any other possibilities?? Doug Rodrigues 08-14-2005, 12:40 AM I think that you're correct. However, if the engine has been seriously overheated, it could also be a cracked cylinder too. In the past, I've bored and sleeved a few of those too, mostly caused from overheating. Hope that isn't the problem. drive 09-22-2005, 11:02 PM If you have a sloppy timming chain it might have worn through the cover into the water pump passage. common to happen. when those plastc guides break thats what happends. do a compression test. If its fine its probablty that cover. Automotive Network, Inc., Copyright ©2012
