Stereo wiring diagram for '94 GC Laredopete44 08-13-2005, 08:26 AM Need a stereo wiring diagram for '94 Grand Cherokee Laredo.(Installing aftermarket stereo..Previous owner took his out (speakers included)...It has 2 harnesses where stereo was(I'm assuming 1 for power and 1 for speakers)and antenna and ground hookup at dash..I have installed 4 door speakers and new power antenna that all need hooking up........Thanks,Pete44 dksob81 08-13-2005, 11:55 PM Does it have Power AMP (under the rear passenger seat (driverside)? dksob81 08-14-2005, 12:07 AM Also could you give me the # of wires there are and what the colors are, and I iwll let you knwo which wire (by color) goes to where. email me.... Joe dksob81@hotmail.com with your info. dksob81 08-14-2005, 01:52 PM Radio w/ Power AMP Radio Connector: BLACK HARNESS: PIN Wire description Color 1. AMP On/OFF signal/antenna up signal Dark Green/Red 2. Left rear speaker feed (+) Brown/Yellow 3. Right rear speaker feed (+) Dark Blue/White 4. Left front speaker feed (+) Dark Green 5. Right front speaker feed (+) Violet/Yellow 6. Left rear speaker return (-) Brown/Light Blue 7. Right rear speaker return (-) Dark Blue/Pink GRAY HARNESS: PIN Wire Description Color 1. Radio Mute 2. Left front speaker return (-) Brown/Red 3. Right front speaker return (-) Dark Blue 4. Marker (Head/Park Lamp) Dark Blue/Red 5. Dimmer (Panel, Lamps, Variable) Orange 6. Accessory (Switched B+) Red/Grey 7. Battery (Memory) Red/White pete44 08-14-2005, 05:47 PM thanks dksob81...this should really help!..I think under my rear seat is labeled where amp used to be....Thanks again, Pete44 dksob81 08-14-2005, 06:26 PM If you need any other info. Let us know. putxemxup 08-26-2005, 12:46 PM i need this asap sum1 please help, i need a diagram with colors of the wires, for insstalling a aftermakret radio dksob81 08-28-2005, 11:42 AM I posted the wiring with color and description up above Automotive Network, Inc., Copyright ©2012
