Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-13-2005, 01:23 AM   #1
Will09
Will09 Normal reputation
front speaker removal
need to know how to remove front speaker panel so i can put in new speakers. also ne suggestions on speakers.
thanks
Will09 is offline   Reply With Quote
Old 10-07-2005, 09:56 PM   #2
gameguru1360
gameguru1360 Normal reputation
Send a message via Yahoo to gameguru1360
for what year corolla are you asking for??
gameguru1360 is offline   Reply With Quote
Old 10-17-2005, 10:00 PM   #3
lbreaud
lbreaud Normal reputation
ive replaced all the speakers on my '02. the door panels are connected via small plastic pegs that hold it in place on the door. There is a screw located in the middle of the door handle, which needs to come out. If you pull up the rubber lining on the arm rest, youll see two screws there as well. To remove the instrument cluster on the arm rest you will need a flat head screw driver. There is a small gap or indentation on the panel where the actual buttons are located. Pry this panel up and disconnect the harnesses to finish the removal of the door panel. From there youll see the speaker with prob. four screws holding it in. For my car i had to cut and splice the stock wires (they were connected to the stock speakers with a sort of "boot") to the aftermarket speakers.
Another thing to keep in mind is the depth of the new speakers. The new ones i had were too deep and the window scraped against them when i lowered them all the way. This is a bad way to find out, so make sure you check your depth before you try this. I fixed it with a few spacers.
lbreaud is offline   Reply With Quote
Old 10-20-2005, 11:16 PM   #4
BiGwiLLswiLLy
BiGwiLLswiLLy
Send a message via AIM to BiGwiLLswiLLy
you have an older corolla where they are on the lower part of the dash?
BiGwiLLswiLLy is offline   Reply With Quote
Bookmarks
Google
Web AF
