Re: how to remove the dashboard?
there are 2 screws on the driverside kick panel, take them out, leva the panel hang there, and set the e brake. Then turn the key to on, and shift lever all the way down to 1, and then the dash sould just all pop out of place. you will have to finangle that sucker out from around the steering column, but it can be done. Good luck
2000 Pontiac Grand Prix GTP
(3.4" Pulley, DHP 1.5 Powertuned PCM, ZZP 2.5" High Flow Downpipe, MMS Ported and Polished Lower Intake Manifold, ZZP Stage 1 Ported Throttle Body, 180° Thermostat, NGK Iridium TR6IX)
1997 Chevrolet Silverado K1500 4x4 350
(soon to come,true dual exhaust, roll-up access tonneau cover, light bar)
Check this out! (Good Stuff)
Honda Cog Commercial
