A/C compressors for intrep
flrydr
08-12-2005, 11:28 PM
my compressor bearings failed on my 94 Intrepid so I would like to get a used one from the yard but, what other dodge/chryslers compressors will fit the 94 intrepid?
thanks
theFREAKnasty82
08-16-2005, 10:55 PM
'93-97 Intrepid, Chrysler Concorde, or Chrysler LHS, depending on the engine. It varies between engines, either the 3.3 or 3.5.
OrangeParkTech
08-19-2005, 11:16 AM
the 3.5 and 3.3 have the same compressor. at least the 97 concorde one i got worked in my 96 intrepid fine.
dahobbs
08-19-2005, 05:39 PM
You CAN purchase the bearing for the compressor and rebuild it yourself. I have done many of them in the past. The compressors are so simple, its really dumb to buy a new or remanufactured compressor from an autoparts store.
Most fail due to the following:
Front shaft seal leaks: Replacement around $9
Leaking "O" ring: around $8
Bad Internal bearings: approx $26
Bad Clutch Bearing: approx $45
Most parts I purchse locally but there are several bearing suppliers online, also John Deere equipment also use the same compressor.
Here are a few sites:
http://www.polarbearinc.com/PBPC/homepage/Search/GA/Seals_GA_Metal.html
!! Seals and such:
http://www.apairinc.com/iVIEW.asp?CAT=Compressor%20Seal%20Kits&SCAT=Nippondenso
http://www.apairinc.com/main.asp
(there main page)
Bearings:
http://bearingsdirect.com/products/
Condensor Lookup:
http://webbase.transpro.com/coolcat/
TSB's & Recalls:
http://www.alldata.com/recall/make/
I hope this helps at least ONE person out there, because I have learned alot from reading the forums.
Dave
