96 grand cherokee died,no restartconverter45 08-12-2005, 10:25 PM have a 96 grand cherokee 4.0 litre. died while driving and no restart. cranks ok,no communication to scan tool,no spark,no fuel pump relay or auto shut down relay activaction. instruments do not read(volt meter, oil,tach,fuel gauge. tried a known working E.C.M. made no difference. has power to ECM and all outputs at ignition switch. other accessories in car work OK. any ideas? :banghead: dksob81 08-12-2005, 11:29 PM have a 96 grand cherokee 4.0 litre. died while driving and no restart. cranks ok,no communication to scan tool,no spark,no fuel pump relay or auto shut down relay activaction. instruments do not read(volt meter, oil,tach,fuel gauge. tried a known working E.C.M. made no difference. has power to ECM and all outputs at ignition switch. other accessories in car work OK. any ideas? :banghead: Does your CHECK ENGINE light come on when you turn the key to the ON Position? converter45 08-15-2005, 09:37 PM Does your CHECK ENGINE light come on when you turn the key to the ON Position? (from converter 45) went through some of the other listed problems,and found one that sounded the same as mine. I replaced the crank position sensor and to my suprise,everything came back to life and solved the problem. dksob81 08-15-2005, 10:24 PM This is the reason I asked if the CHECK ENGINE light comes on when you turn the key. When the CPS goes bad the CHECK ENGINE light usually will not illuminate. Automotive Network, Inc., Copyright ©2012
