Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 08-12-2005, 12:09 PM   #1
chamm
chamm Normal reputation
1972 c10 used to "grind" goin in first gear, now no clutch at all
my 1972 c10 used to gring going into first gear and the clutch had a very low release point. Now i cant get it to go into gear at all but it drive fine if i crank it while in gear, in all gears......pressure plate??, slave cylinder???
chamm is offline   Reply With Quote
Old 08-12-2005, 07:59 PM   #2
robertjr
robertjr's Avatar
robertjr Normal reputation
Re: 1972 c10 used to "grind" goin in first gear, now no clutch at all
I would check the adjustment on the linkage you should have a mechanical linkage clutch on a '72 unless one or someone else converted it to hydrolic. Also check for slop in the linkage or worn out brushings if that all checks out. Inspect your throw out bearing and clutch fork assembly and fulcrum point.
robertjr is offline   Reply With Quote
Bookmarks
Google
Web AF
