Rebuilt motor with Disco Potato Turbo OPINIONS??
RM2 2000GT
08-11-2005, 09:51 AM
I am seriously considering buying this 1992 MR2 with this recently built engine. I need some honest opinions. I will be paying roughly 11000-12000 US Dollars. If everything is in good shape and is running smoothly, what do you think???
173,000 miles on the odometer
Clean Title, no accidents.
6000 miles since the rebuild on all components listed below.
ENGINE
Built by Bayshore Racing of San Francisco
Head
ferrea stainless intake/exhaust valves
titanium retainers
ferrea splitlocks
hks springs
stock cams
hks camgears
radial valve job
port and polished
decked
Block
CP custom forged pistons
shot-peened conrods
all new ARP hardware including headbolts, conrod bolts, main bearing bolts, flywheel bolts
entire assembly race balanced from pulley to flywheel
New oil, water pump, both idlers, tensioner, belts
OTHER
port and polished, port matched: throttle body horn, intake manifold, TVIS butterfly, head, exhaust manifold, turbo adapter, turbo inlet.
brand new TVIS butterfly set*
All hoses new on entire motor
RPS clutch
alternator, starter
TURBO AND EXHAUST
Garrett GT-28rs (disco potato) ballbearing turbo, internal wastegate
3 inch stainless downpipe
custom 3 inch exhaust, stainless magnaflow muffler
GReddy Intercooler and piping
manual boost controller
hks turbo timer
COOLING
All new coolant piping
Radiator re-cored
FUEL
Walbro fuel pump
factory injectors balanced by RC Engineering to 450cc
SUSPENSION, BRAKES, ECT
tokico 5 ways in front, koni 4 way in rear
new toyota brakes and rotors
yokohama avs es100 tires on all four rims
ST front sway bar
new lower ball joint on all 4 corners
new tie rod ends
*All components replaced with genuine toyota parts, unless otherwise specified
ac427cpe
08-11-2005, 09:54 PM
hard to tell w/o pics... i'm assuming in norcal. the owner might get that much, but i probably wouldn't go higer than 8-9k with what is done.
MR2turbo93
08-11-2005, 11:52 PM
yea you never know how someone treats their car regardless of how new the motor is .... thats a lot of work
