instrument panel lights.
Iz6
08-10-2005, 09:33 PM
Map lights work , overhead light works but nothing else lights up inside. I figure there is a fuse but can't find fuse block inside. 1996 monte carlo z34. Anyone know where the inside fuse block is at. The owners manual says MOST of the time it is on the passengers side of the instrument panel...but not on mine. Thanks in advance for any suggestions.
Jim Adams
08-11-2005, 04:37 AM
if you have no dash or intrument lights but have map lights then the acc. light fuse is good ,,your problem is going to be in your head light switch,,,I had this problem with a cadilac and I pulled the headlight switch down and used a jumper wire and located the wire feed for the instrument lights and then jumped off the switched hot wire for the headlights and into the instrument lights wire feed,,I had a problem in the switch and jumping threw it fixed the problem this was about 7 months ago and no problems yet, they wanted 83 bucks for the switch and the jumper wire cost me nothing lol
Iz6
08-11-2005, 09:02 AM
I'll check it....thanks
Iz6
08-11-2005, 10:15 AM
Turns out that did the trick...thanks alot! I still wonder where the inside fuse block is though, never seen one without one inside. I found the 2 under the hood.
Iz6
08-11-2005, 09:31 PM
Found it....open passenger side door and it is on the far right of the dash
