99 cavalier center console removal
antonehenry
08-10-2005, 04:46 AM
i can't find all the screws, and searched for a simillar topic.
little help please?
oh and there's some weird thing in my cubbie under the dash that i think i need to pop off... but can't. :/
antonehenry
08-10-2005, 05:14 PM
well figured it out.
a bolt in the front cubbie thing. 2 screws next to the auto-shifter. 2 bolt in the bottom of the center compartment. and then 1 bolt by the 2 screws.
10mm socket was needed. i bought some amercian sized ones for my american car... nope, they were metric. woo
Aubrey Daniel
11-04-2005, 08:52 AM
I need to remove mine also. I cant find the front bolt in mine. all of the console is loose but what seems to be one last bolt in the front of the console, but I cant find it. Does something pop off for access?
antonehenry
11-04-2005, 10:00 AM
I have the console loose all but what seems to be one front bolt but I cant find it. can you help?
wow, haven't been here since, but yes!
there are two in the box itself, there's one up front that you have to pull a little cap off with a flathead screwdriver first, then there's a couple or few under the shifter that you can pop off part of the console there....
the only tricky ones i recall are that one in the front cubbie, and under the shifter. the others should be easy to find.
to remove the shifter head, there's a U shaped pin on the windsheild side taht you have to pull out. that's a little frustrating, i just jabbed a lot with a flat head, but a needle nose / flathead combo would work nicer.
