'95 Laredo G.C.Door panel removalmoldmaker 08-09-2005, 10:35 PM I have two door panels that I will need to remove. The front passenger door for a door lock that will not operate using the power locks. The rear drivers side door where the power window button has been shoved into the door. I need to know how to remove the panels and what parts I will need to replace to put the panels on the doors, such as clips or screws. I realize that the parts needed to repair the lock and window button may not be known until I get the panels off. Also, where can I get the parts that will be needed? Thanks in advanced. dksob81 08-10-2005, 08:14 AM well before removing the FRONT PASSENGER DOOR PANEL, Check the wiring between the door jam look at the PINK/BLACK wire and the BLACK/WHITE wire chances are one or both oof these wires are broke. To access the wires open the door all the way and between the two hinges you will see the boot covering the wires, pull the end of the boot out of the frame side of the jeep first and stick that end inside the hole then pull the other end off the door and slide as much of the boot into the jeep through the hole as possible, this will make locating and repairing any broken wires easier. Automotive Network, Inc., Copyright ©2012
