MBC install question
blk_srt
08-08-2005, 03:50 PM
Ok ive done some searching and i cant find exactly what i need, so here it is. first off i just god a new mbc and i need a little help with the install. correct me if im wrong but one side of the mbc connects to the wastegate and the other to a boost sourse? well the wastegate is connected to the bov and the bov is connected to the manifold, so can i just splice the mbc in the vacuum line from the wastegate to the bov or what?
LouieAWDTSi
08-09-2005, 02:50 PM
Just run one directly to your wastegate actuator to your mbc. T into the hose that goes from your BOV to your intake manifold and run that off the T to your boost source on the mbc. Any ?'s check out plymouthlaser.com and look at turbo related ?'s. It has a mbc install. Good Luck. Make sure you keep your bcs plugg in or you will have a CEL light come on in your dash.
laser apexi turbo
11-01-2005, 08:38 PM
ive only installed one one mbc, and it was on a 88 supra. It took me a while of thinkin about it but anyways. there was just simply a hose going from the actuator to the turob like right behind it. that simple. like a 7 inch vac hose. so since it was only 7 inches i just went to partsource picked up some vaccum hose that was like 3 feet long and cut it in half. pout the controller in beetween it and mounted it by the wheel well and she workes leik a charm. raising it from 5 pounds to about 12-13. not bad for a $2 peice off ebay
