Originally Posted by shadow163
i do believe i fixed the antenna problem. it must have been loose. i went out and bought a small saw to try and cut through some of the plastic in the back after i burnt out another fuse. every time i unplug the dome light/dimmer switch fuse and plug it back in the fuse seems to pop. i dont know why it just does although it could be from unpluging the raido and pluging it back in since that fuse seems to be tied into the radio.
I just used side cutters.. you dont gotta take away alot just the part the crosses over in the corners and the middle part that stick up.
just leave the fuse unplugged till everything is back in.
I believe i did the same thing.. I only poped one fuse... its prolly because the dome light and radio is on the same circut .. too much current all at once or something.
