1992 Eclipse Check Engine Light is on where is the service connectorbratt 08-08-2005, 02:36 AM how to i pull the codes for a 92 eclipse is there a service connector some where i can short to get a morse code read out??? let me know please david-b 08-08-2005, 11:20 AM You have to jump a wire in the hookup. I rememeber I had to do it to my bros car, but dont remember how. bratt 08-08-2005, 11:16 PM well try to remember just tell me where that service connector / plug is and i'll try to do it is it under the passenger or driver side side panel is it behind the stereo what does it look like please 1stGenRocks 08-08-2005, 11:37 PM drivers side above the fusebox. underneath the dash. it probably has a little black rubber cover over it. you hook a analog voltmeter or a small buzzer to 2 of the pins and it beeps out the codes. search for a post by landoawd that says which pins and what the codes are. the title is sopmething like how to read codes in a 1g. ill try and find it for you but this will get you started. chiltons also has directions and vfaq.com might have them too bratt 08-08-2005, 11:50 PM IS THIS IT??? You can find alot of "what if" answers by doing a SIMPLE diagnostic check. And every newb asks the same question over and over about idling and surging...check your diagnostics. Follow these steps: WITH THE KEY OFF 1. Look undwer the dash on the driver side. 2. There is a vertical plug, sometimes with a cover, thats rectangle (this is the Data Link Connector). 3. Looking at the plug youll notice that there are only a few terminals. Now using an voltmeter connect the pos to the TOP LEFT (OBD OUTPT), and the ground to the BOTTOM RIGHT (Ground). 4. Turn the key into the on Position. It will give you a read out it passes. Either Long or short jumps with the needle. Record your findings then check the code. It always reads Long jumps then short jumps, and it will repeat over and over. CODES and Problem 1.8L LS -02 Sensor LSS -Air flow sensor LSSS -Intake air temp sensor LSSSS -TPS LSSSSS -Motor position sensor. LLS -Engine coolant temp sensor LLSS -Crank angle sensor LLSSS -No. 1 cylinder TDC sensor LLSSSS -Speed sensor LLSSSSS -Barometric Pressure sensor LLLSSSSSS -Ignition timing adjustment signal LLLLS -Injector LLLLSS -Fuel Pump LLLLSSS -EGR <California> SSSSSSSS -Normal 2.0L LS -02 Sensor LSS -Air flow sensor LSSS -Intake air temp sensor LSSSS -TPS LSSSSS -Motor position sensor. LLS -Engine coolant temp sensor LLSS -Crank angle sensor LLSSS -No. 1 cylinder TDC sensor LLSSSS -Speed sensor LLSSSSS -Barometric Pressure sensor LLLS -Detonation Sensor <Turbo> LLLLS -Injector LLLLSS -Fuel Pump LLLLSSS -EGR <California> LLLLSSSS -Ignition Coil SSSSSSSS -Normal Info From Chilton Manual. Try it anyway, you never know what could be wrong. david-b 08-09-2005, 02:36 PM Yup bratt 08-17-2005, 06:30 PM LLSSSSS -Barometric Pressure sensor LSS -Air flow sensor LSSS -Intake air temp sensor im pulling these three codes does any1 know where these 3 sensors are so i can clean them or replace them or check the wires! 1stGenRocks 08-18-2005, 10:50 PM those sensors are all in the mas unit thats inside the the airfilter. my guess is that the plug came loose or you unplugged it and forgot to put it back Automotive Network, Inc., Copyright ©2012
