Re: oil in the radiator
so whats Haynes have to say about oil in the Antifreeze? definately not good? Was it just oil, no H2o or green at all? I would find it odd to have nothing But Oil in the radiator, unless someone put it in there. If that is the case, just oil, i'd look for blown gaskets head/intake big cracks. honestly Id junk it! Personally i've not seen any 2.4's(quad 4) that werent leaking something. You'd probley be better off scrapping it, but with any caar you'll have trouble thats garenteed. the newer it is the more, generally, the parts can cost.
you can find a nice 93-97 GA pretty cheap. in my area for $3000-4000$ will get a decent ride. just look for lower mileage and check for leakage under the car your lookin at. Non smokers/lady driven, garaged, those are things I'd look for and try to stay away from 2.4's. people think it gets better MPG but this isnt true. the smaller engine has to work harder,than a larger engine, to pull the same weight . But if you really like ur 90' and if ur willin to learn and get dirty an engine would be cheaper then a newr ride. hope this helps Penster!
