Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 08-05-2005, 05:46 PM   #1
NY91TegOwner
NY91TegOwner Normal reputation
Send a message via AIM to NY91TegOwner
Talking After I/H/E should i go internal or slap on a turbo
Ok i've solved my problem with th I/H/E and now i am not sure whether i shoudl go internal and start changing that stuff or should i just slap on a turbo??
NY91TegOwner is offline   Reply With Quote
Old 08-05-2005, 07:44 PM   #2
K2sInteg98
K2sInteg98 Normal reputation
well you need to do a little more research. you really cant just "slap on" a turbo. a turbo kit will give you the biggest bang for your buck but i would make sure your engine is ready for it. Make sure the exhaust you have is around 2.5-3" and i would strongly reccomend building your internals. rods,pistons,etc. once you've built your internals then you'll be ready for turbo and be able to push over 8 psi because your internals wont be stock.
K2sInteg98 is offline   Reply With Quote
Old 08-05-2005, 07:59 PM   #3
Rating
Rating's Avatar
Rating Normal reputation
Send a message via AIM to Rating
Re: After I/H/E should i go internal or slap on a turbo
Yea man, I did the slap on the turbo things, and now im rebuilding because of it. I studied up on tunning for a turbo, definatley build your motor and other applications, such as mounts, clutch tranny build... cooling system... etc etc. Just slappin a turbo on isnt the way to go.
Unless you wanna do this...
or this...
if you go to my thread, you can see some of the changes I've made
http://www.automotiveforums.com/vbul...d.php?t=294631
Im not proud of my car because its fast, Im proud of it be cause I built it that way.
Rating is offline   Reply With Quote
Old 08-05-2005, 10:56 PM   #4
slmdintegra98
slmdintegra98 Normal reputation
yeah man i would go internal first because if u dont u will only be able to run 5-7 psi on the stock cams,rods,and,pistons.but after words when u go for a turbo make sure u find a good turbo that will give u the max hp gain.
slmdintegra98 is offline   Reply With Quote
Bookmarks
Google
Web AF
