big lose of power running lean helpwilddelsolkid420 08-05-2005, 11:42 AM hello i got a 93 toyota pick up in colorado and it moved there from maryland and the owner told me when he moved that the truck had a lose of power i live in oklahoma now and i am woundering if any one knows what is wrong i also pulled a spark plug and noticed it was running way lean..does anyone have help? i was also told it could be the O2 censor any one no if that is true? toyotruck88 08-20-2005, 10:42 PM Yes O2 sensor is a good place to start... We are talking about the 22RE (2.4L 4Cyl), right? They need to be replaced every 60K I think - They Indicate O2 present in exhaust and the data (a voltage reading from 0 -1 volt) is sent to the EFI Computer... There are a bunch of Sensors for EFI.... - Grab a manual and start playing.... wilddelsolkid420 08-22-2005, 08:43 AM yes its the 22re thanks for the help ill try the o2 sensor uibalnme 12-05-2005, 03:34 PM O2 sensors help in th fuel economy, not so much in power. Check the ignition timing, and adjust if needed. Bad ignition timing plays a big part in power loss. 94yota4x4 12-07-2005, 12:56 PM O2 sensors help in th fuel economy, not so much in power. Check the ignition timing, and adjust if needed. Bad ignition timing plays a big part in power loss. Hi i'm new. My 94 4x4 22re gets bad gas mileage and is underpowered. Just rebuilt the engine completely. Even added a torker cam and cold air induction. Checked the timing about 3 times so far with te1 and e1 jumped. Engine runs exactly the same as before the rebuild. My shop has a Snap On Modis scanner, when i hook it up to read the data while its running it gives me very erratic readings, even sometimes looses communication then regians it. Anyone else have this problem? Possible computer? Automotive Network, Inc., Copyright ©2012
