injector testing (in car)meuhus 08-05-2005, 11:33 AM i was told by a mechanic that the inject resitance on a 91 lumina w/3.1 was supposed to be 14.8-to 15.8 ohms is this correct? i tested mine w/a fluke digital ohm ac/dc meter the ohms can only be read in the 1k setting the readins i got when testing them in the car wire harness un plugged was 12 except for the #6 injector it said 2 (i tested the injectors in my old cutlass just to compare they were all 12 it runs fine) so i tested with my anolog radio shack tester they all tested closer to what the mechanic said depending on witch setting i had the ohms on am i doing something wrong does any body know what the restance should be? or how to test for a bad one in car with ohm meter can you diagnos a bad injector in the car like that? car is not running very well spitts and sputters still like decribed in my other posting i put the map sensor out of the lumina into my blazer to test it the blazer ran fine w/ the lumina's sensor not getting any codes just wondering if any body can help tblake 08-05-2005, 01:01 PM You can do a fuel injector balence test on them. If you get 12ohms across the board, all but for one that gives you 2 ohms. You probably have a bad injector. meuhus 08-05-2005, 01:09 PM You can do a fuel injector balence test on them. If you get 12ohms across the board, all but for one that gives you 2 ohms. You probably have a bad injector. But it test fine with a anolog meter meuhus 08-05-2005, 01:21 PM But it test fine with a anolog meter how do you do balance test? mobil_12 08-07-2005, 07:50 PM A fluke multimeter is like a mercedes. It dont get much better. :bananasmi Resistance values on injectors doesnt matter as much as are they all about the same? Injector resistance will change with temp range. If you have 5 at 12ohms and 1 at 2ohms, you got a bad injector. Another way to test them is listening for clicking noise at each injector with a stethoscope. :screwy: Sounds crazy, but it works! meuhus 08-08-2005, 09:56 AM A fluke multimeter is like a mercedes. It dont get much better. :bananasmi Resistance values on injectors doesnt matter as much as are they all about the same? Injector resistance will change with temp range. If you have 5 at 12ohms and 1 at 2ohms, you got a bad injector. Another way to test them is listening for clicking noise at each injector with a stethoscope. :screwy: Sounds crazy, but it works! i did listen to them before testing them with a screw driver the only ones i could get to with the manifold on were #1and #6 both were clicking (or so i thought) but when i removed the maniford to look at other injectors and tested them 12 is what i got w/ the non-adjustable meter then tried with a different fluke adjustable ohm meter was better #6 shows 2.2 ohms but its clicking that one must be realy broke i hope haven't done much testing of fuel injection another on said 11.6 low side of being good so i think im replacing them all found a site were injectors are cheep hopfully they are as good as they say they are fixed it bad injector thanks all Automotive Network, Inc., Copyright ©2012
