Re: Rich Fuel Bank 1 & 2 Error Codes
When they tested the fuel pressure regulator, did they take off the top half (plastic) of the intake manifold? They are prone to leaking fuel thru the vacuum line. To really inspect the fpr, you need to pull this hose and make sure fuel is not leaking.
If you drive it and let it set for 1/2 hour, how does it start? Right up or does it take longer than normal?
//2000CAYukon
