Originally Posted by spudglo08
All Z71's come standard with lockers.GM doesnt offer limited slip diffs in trucks only automatic locking diffs or open diffs as far as i know.
The optional Eaton G80 locker is different than the regular limited slip that is also available on these trucks.
I don't see a fluid change interval in my owner's manual, just periodic checks. However, mine is due for a fluid change because it's starting to chatter when hot. Eaton says NOT to use limited slip additive in their differentials, as it leaves a residue on the steel discs that can make it worse. It uses 75w90 synthetic I believe.
