1996 V6 Rodeo P0401 Check Engine Light
leaning
08-04-2005, 01:23 PM
Hello.
I have removed the EGR valve and sprayed it with cleaner. Got lots of black carbon flakes. Made sure I cleaned the pintle.
Sprayed both holes where the EGR connects (intake and exhaust).
Re-installed the valve with a new lead gasket.
Still have the "EGR flow insufficient" code.
1) Where is the venturi (d/p) sensor for low flow? Is it part of the EGR valve, or does it read off somewhere else?
2) The tube that goes down into the intake manifold I cleaned using pipe cleaners. Got some off of that. If I remove the intake manifold, is there more to this tube to clean, or should I leave it alone?
3) The main problems with this Rodeo are that it sucks up oil (which seems to be a common problem), has a real hot engine temp, smells like burnt coolant (even though I can't find a leak), and this goofy, recurring P0401 code CEL.
4) Any other suggestions on things I can look at? I don't want to pull the intake manifold off if I don't have to, or replace the EGR valve if there is something else that it could be.
Thanks for the help!
John
