Sick Neonchigowolfs76 08-04-2005, 08:33 AM Oh welll I am now a proud owner of a sick neon. I currently have no compression from #2 and I am in the process of ripping the head apart. The valves seem fine.... Wish me luck!!!! das2123 08-04-2005, 09:04 AM Oh welll I am now a proud owner of a sick neon. I currently have no compression from #2 and I am in the process of ripping the head apart. The valves seem fine.... Wish me luck!!!!Did you do a leakdown test first? And good luck! chigowolfs76 08-04-2005, 09:30 AM No I did not do a leak test.. I pulled the spark plug, placed my hand over it... NO COMPRESION... other 3 are fine... I replaced the plug also yesterday... #2 had a residue on it, and was clean ( not firing) chigowolfs76 08-04-2005, 10:04 AM Ok, found some info to my problem. looks like maybe a valve job.... I will find out more on sunday, when I will have time to look at it again, and do a correct compression test!!! maykelcj 08-06-2005, 06:18 AM looks like you need to sit your valves. Have you ever have had problem with the timming belt? couse if you bent a valve you get the same simtom. royerjay 08-09-2005, 05:56 PM i got a problem well actully two problems, anyway i had a friend of mine install a short ram air intake on my car but i think he did it wrong by putting the oil hose from the valve cover into the silicone short ram air hose and i never seen that done before. das2123 08-09-2005, 07:25 PM i got a problem well actully two problems, anyway i had a friend of mine install a short ram air intake on my car but i think he did it wrong by putting the oil hose from the valve cover into the silicone short ram air hose and i never seen that done before.That is the way it goes. chigowolfs76 08-10-2005, 09:34 AM looks like you need to sit your valves. Have you ever have had problem with the timming belt? couse if you bent a valve you get the same simtom. Ok how hard of a job would it be to re-sit the valves??? maykelcj 08-10-2005, 03:15 PM Ok how hard of a job would it be to re-sit the valves??? it's not that hard is just a lot of work. it is explaned in the chilton manual. chigowolfs76 08-10-2005, 03:19 PM it's not that hard is just a lot of work. it is explaned in the chilton manual. Which would be better to get, Chilton, or the Hayes???? das2123 08-10-2005, 03:57 PM Which would be better to get, Chilton, or the Hayes????FSM would be the best, followed by Chilton's, then Haynes. I have all 3 :p chigowolfs76 08-10-2005, 03:59 PM Damn your in texas..... hmmm got a scanner???? Just Kiddin.....I will end out getting the hayes probaly das2123 08-10-2005, 04:03 PM Damn your in texas..... hmmm got a scanner???? Just Kiddin.....I will end out getting the hayes probalyIn Houston and I have an OBD II AutoScanner CP 9135 Actron. chigowolfs76 08-10-2005, 04:23 PM Actually I was talking about a scanner to scan the FSM!!!! das2123 08-10-2005, 04:31 PM Actually I was talking about a scanner to scan the FSM!!!!I have something that will help, what's your email address? maykelcj 08-10-2005, 04:31 PM Actually I was talking about a scanner to scan the FSM!!!! I think if you go to the public library they must have automotive manuals and stuff. Here in Gainesville FL they have two shelfs full of automotive stuff. chigowolfs76 08-15-2005, 08:39 AM WOOT!!!! got lucky on my Neon, Just a broken Valve Spring, seats are in perfect cond. or are the Valve and stem!!! Now I just have to locate Springs.. Should I go ahead and replace all the springs since I have the head off?? TIA das2123 08-15-2005, 09:47 AM Should I go ahead and replace all the springs since I have the head off?? TIAI vote for springs, lifters, and cam/cams while you have the head off! chigowolfs76 08-15-2005, 10:06 AM Called my local dealer... I really like dealing with them.... Talked to the about the valve spring, said he has never really head of one breaking in the 01 r/t's.... well I ordered 1 spring and a headset not bad price $111.00 plus tax... I will have my car back !!!! maykelcj 08-17-2005, 12:06 AM Called my local dealer... I really like dealing with them.... Talked to the about the valve spring, said he has never really head of one breaking in the 01 r/t's.... well I ordered 1 spring and a headset not bad price $111.00 plus tax... I will have my car back !!!! Good luck!!! while you are at it, sit the valves. chigowolfs76 08-26-2005, 04:03 PM well I should have my neon back this weekend... I miss her.... My has been busy with some side-job, ( he is the mechanic in the family) I wont complain he wont charge me for doing the work.... I thought I posted in this thread that it ended up being a broken valve spring.... anyone ever hear of someone breaking a valve spring in a 01 neon rt??? the parts dept. at my local dealer didnt...... this weekend will consist of putting the engine back together.... Automotive Network, Inc., Copyright ©2012
