AC filter on 2002 AccordCeelo 08-02-2005, 08:03 PM I need some help on installing an element filter on a 2002 honda accord v6 sedan! Your help is appreciated! BullShifter 08-03-2005, 02:48 AM It's pretty simple Open passenger side door, pop of side panel Remove panel under glove box - 2 screws, one behind that 1st panel remove, pop off panel under radio for 1 more screw Remove 4 screws in glove box(2 at the latch, 2 under plastic covers that pop off, remove screws to the lower part of glove box. Pull out glove box, disconnect light Remove 2 metal braces Pop off filter cover - remove filters Before installing new filters turn the blower motor on high to blow out any crap that has built up. I cover the opening with one of the old filters so it doesn't make a mess inside the car. Install new filters in plastic holders and reverse process. Hope this helps because it's a lot easier to do than explain process. hondagirl23 08-17-2005, 01:12 AM A member just sent me here for ac filter change on a 98 Accord. Is it similar instructions? Will changing filter affect cooling at all? Hope Hope..Just curious... It's pretty simple Open passenger side door, pop of side panel Remove panel under glove box - 2 screws, one behind that 1st panel remove, pop off panel under radio for 1 more screw Remove 4 screws in glove box(2 at the latch, 2 under plastic covers that pop off, remove screws to the lower part of glove box. Pull out glove box, disconnect light Remove 2 metal braces Pop off filter cover - remove filters Before installing new filters turn the blower motor on high to blow out any crap that has built up. I cover the opening with one of the old filters so it doesn't make a mess inside the car. Install new filters in plastic holders and reverse process. Hope this helps because it's a lot easier to do than explain process. Automotive Network, Inc., Copyright ©2012
