Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 08-02-2005, 10:41 AM   #1
tsutton
tsutton Normal reputation
AC not blowing- Vent problems
The AC in my 97 does not blow well out of the vents. The air is cool but the flow is very weak. When I change blower settings I can hear the vent doors move so I don't think it's the switch or vent controls.
Any idea's as to what is causing this problem? Blockage?
tsutton is offline   Reply With Quote
Old 08-02-2005, 04:38 PM   #2
Beasty
Beasty Normal reputation
My 83 has a vent hose that attaches to the under side of the dashbard from where the vent comes in at the firewall. The hose is located behind the glove compartment. It has to disconnect to pull the dash, so maybe if you've recently had a stereo or windshield installed it could have gotten knocked loose..not sure it'll help at all considering difference in years, but hey...it's something.
Beasty is offline   Reply With Quote
Old 08-02-2005, 06:07 PM   #3
2000CAYukon
2000CAYukon Normal reputation
Re: AC not blowing- Vent problems
Take a look at my post in this thread http://www.automotiveforums.com/vbul...d.php?t=439207
//2000CAYukon
2000CAYukon is offline   Reply With Quote
Old 08-02-2005, 07:53 PM   #4
nascarmechanic
nascarmechanic Normal reputation
Send a message via AIM to nascarmechanic Send a message via MSN to nascarmechanic Send a message via Yahoo to nascarmechanic
Take out the blower motor and visually inspect the evap. core. My 89 had the same issue and it turns out the previous owner was a dog owner and it's hair plugged up the cooling fins on the evap. not allowing any air flow. Freezing of the Evap would cause the vents to not work only after time... not all the time.
nascarmechanic is offline   Reply With Quote
Old 08-03-2005, 04:30 AM   #5
Tall
Tall Normal reputation
Have you replaced ur stereo in that car? Or has it ever been replaced?
Tall is offline   Reply With Quote
Old 08-03-2005, 07:44 AM   #6
tsutton
Yes, I replaced the stereo a couple of months ago. Could I have knocked something loose? What should I be looking for? Thanks for all the great replies!
Old 08-03-2005, 01:55 PM   #7
Tall
Well, the 97s have the A/C electrical bored right below the stereo, and it’s exposed…
Now, the Antenna Adaptor for the GM trucks can be made out of metal, or have metal parts…put metal contacting the circuit bored…and you just caused your self a problem.
Test all the controls to make sure they work. Now I know the fan speed is the problem. When you increase it, does ANY more air come out, or does it feel the same, no matter how high, or low you go?
Old 08-03-2005, 02:02 PM   #8
tsutton
I definately get more air flow when I increase the fan speed. Unfortunately even on high the flow is minimal.
Old 08-04-2005, 08:53 PM   #9
nascarmechanic
clean the evap. core......
Old 08-08-2005, 10:10 AM   #10
tsutton
How do I clean the evaporator core? Where is it?
Old 08-09-2005, 05:25 PM   #11
CrazyLegs702
CrazyLegs702 Normal reputation
Try replacing the passenger compartment filter.
CrazyLegs702 is offline   Reply With Quote
Old 08-12-2005, 07:51 AM   #12
tsutton
Do the 97's have a passenger compartment filter? Is that what is in between the evaporator and the blower?
Old 08-12-2005, 02:13 PM   #13
CrazyLegs702
to be honest I dont know but it my 2000 it had one. if its the same theres a plastic cover under the passanger side of the dash thats where my blower fan is. fan should be closer to the passenger door and the filter is near the middle.
Old 08-12-2005, 03:52 PM   #14
2000CAYukon
Re: Re: AC not blowing- Vent problems
No. Only the new body styles (99 and up. 2000 and up on the SUVs) have them.
Bookmarks
Google
Web AF
