need help with HONDATA
Google
Web AF
Vroinshk06
08-02-2005, 03:02 AM
i have a 98 gsr and i am going to buy hondata
ive read a million things and i still dont understand what i need to do to be able to use it. i know i have to convert to obd1 but im lost
can someone tell me exactly what i need to buy and what to do
superbluecivicsi
08-02-2005, 03:24 AM
you are using hondata for?
Rating
08-02-2005, 10:21 PM
Well im not experience with Hondata really,
but im pretty sure all u have to do is get the Hondata system... Install it... Get a Computer...
Install the software... and figure out how to use the software. But dont quote me on that cause I'm not positive thats all.
Also you can find more information here.
http://www.hondata.com/wizard/wiz_start.html
superbluecivicsi
08-03-2005, 01:09 PM
Vroinshk06
08-03-2005, 02:54 PM
tuning
slow_99integra
08-03-2005, 03:08 PM
tuning
Yeah no shit....What do you have done to your GSR? Why do you think you need HONDATA?
Vroinshk06
08-03-2005, 05:10 PM
intake manifold
headers
exhaust
intake
throttle body
pulleys
slow_99integra
08-03-2005, 05:38 PM
you don't need hondata for those mods...Raise compression and get some sick cams, then hondata will be a great idea. or better yet boost then hondata is great
Vroinshk06
08-03-2005, 05:47 PM
should i just invest in an afc, it runs like crap and breaks up in the top end when im on it
CivicSpoon
08-03-2005, 06:07 PM
Probably the IM and throttle body that is doing it. Those are overkill for your setup, and probably causing you to loose power. Maybe try adding more fuel :dunno:
Vroinshk06
08-03-2005, 08:34 PM
i was told that it needed a tune to fix that problem or afc, does that sound right?
superbluecivicsi
08-04-2005, 03:46 AM
my thoughts are.
if your not boosting, using nitrous, or raising compression, then money spent on hondata can go better elsewhere.
slow_99integra
08-04-2005, 12:43 PM
an afc will not help you. you need to either a. put stock im/tb on or B. get cams and valve train with an agressive grind, then tune it with a vafc you will then be very happy. your n/a engine will only use the air your cams will allow in anything else is wasted.
Vroinshk06
08-04-2005, 09:53 PM
if i get the afc now will it run smoother and not break up on the top end?
Google
Web AF
