The 'verts weigh in at about 200 lbs over hardtops, yours should be around 3800 lbs or so. The registration or title should have it on there.
As far as your fuel problem goes, check all your fuel lines back to the tank. The rubber pieces can suck air when they get dry rotted. If all looks well, disconnect the line before the fuel pump, blow it back to the tank, but don't over do it with the pressure. 30 psi will do it. Then reconnect the line to the fuel pump. Now disconnect it at the carb inlet, while someone cranks the motor (disconnect the coil wire), see if any fuel will pump into an empty container. You should get a pint in like 10 seconds. If you get little or nothing, replace the fuel pump.
If you're going to use the car, replace the fuel pump regardless, especially if it has been sitting around. Give the gas in the tank the sniff test, if it smells funky, drop the tank and either replace it or get it boiled out. Treat the sending unit and float very carefully, if you bend something or break off a wire the gage might not work or be inaccurate.
Good luck, Bob
