A/C will not workTridavis 07-30-2005, 06:04 PM I evacuated the system, jumped the compressor and refilled the system, checked for leaks and have found no problems. It will cool when I jump straight to the battery from the comp. But it will not kick on without me doing this. Anyone have any ideas. Thanks. Davis GTP Dad 07-30-2005, 07:53 PM You may have a bad low pressure sensor or a bad compressor fuse. If it will work when you jumper the compressor then there has to be a problem in the activation circuit. I would also check the switch to the AC as it may have gone bad. Tridavis 07-31-2005, 08:30 AM I checked the compressor fuse and it is ok. I am thinking it is the low pressure sensor as well. How do I check this sensor?? Thanks Davis Automotive Network, Inc., Copyright ©2012
