Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 07-30-2005, 11:49 AM   #1
jville777
jville777 Normal reputation
Send a message via AIM to jville777
Exclamation teg ls missing on hard throttle
i have a 95 Ls w/msd sci ign...on occasion (lately more frequently) will misfire or miss or whatgever it's doin, when i jump on the throttle.... seems like tps, but ive checked and it's checking good...????? I have done all work to car myself, and know more about hondas(acuras) than many and can be of help to many questions, however, on this one, im truly baffled....
95 Ls, iceman cai, skunk2 int. man., greddy header, greddy evo exhaust, top speed race cat., msd sci & plug wires, msd injectors, b&m fuel pressure reg., eibach pro-kit springs, kyb struts... and a few tricks that i have learned by testing at the track...
14.17@ 104.6 1/4 no internal mods
need cam. to post pick...<coming soon>
a tru tuner fanatic lives & sleeps the taste of speed
jville777 is offline   Reply With Quote
Old 07-30-2005, 11:58 AM   #2
slow_99integra
slow_99integra's Avatar
slow_99integra Normal reputation
Re: teg ls missing on hard throttle
Timing may be off 18degrees before top dead center. it may also be a bad knock sensor....the car at higher rpms may be advancing the timing. this would be due to a bad knock sensor. Are you still using the same amount of fuel?
They say "speed kills drive a Honda" I say "You're right"
"I'm a kid with a grown man's mind turning corrupt" Wu Syndicate
slow_99integra is offline   Reply With Quote
Old 07-30-2005, 12:05 PM   #3
jville777
only the vtecs had a knock synsor of that year, but the timing is @ 18btdc... i am running only little more fuel (26.25lb/hr @ 43.5psi) which is only 20c.c. more than stock... but what really baffles me is its the same setup i've been running for about 9 months... i gave the car to my wife... she wants new cams which ill ask more about later...
Old 08-03-2005, 03:50 PM   #4
whtteg
whtteg's Avatar
whtteg Normal reputation
Send a message via AIM to whtteg
Have you done a compression and leak down test? If not do that and post up your #'s.
whtteg is offline   Reply With Quote
Old 08-07-2005, 05:03 PM   #5
jville777
yes.. checks were done.... checked out better than expectd for the mileage.... What do you think about the e.c.u.(had a 0gauge power wire ran closely too.) or t.p.s.????
Old 08-07-2005, 05:33 PM   #6
superbluecivicsi
AF - Advisor
superbluecivicsi Normal reputation
so your experiencing misfires. what did checking the spark and fuel tell you? random misfires or cylinder specific misfires?
99% of the time a misfire will occur due to spark problems, fuel problems, or low or uneven cylinder compression.
is the msd ign the only spark related mod you have on the car? any fuel mods?
99 JRSC@9.5 psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
superbluecivicsi is offline   Reply With Quote
Old 08-07-2005, 05:40 PM   #7
jville777
checked ou to.k. also.... i,m under the hood daily.
what do you think about the msd sci connected to internal coil????
Old 08-07-2005, 06:16 PM   #8
superbluecivicsi
AF - Advisor
how do you know you are misfiring????????
if you are misfiring. you will throw codes 71 - 74 (random misfires from cylinder 1 - 4). if you are misfiring, try going back to the oem ignition setup and see what happens.
also, why are you using the msd ignition for?????? what mods do you have that require you to upgrade your ignition system? my experience with the oem ignition system says it works very well.
if you are not misfiring, then, i am going to assume you are boggin in WOT, since you are suggesting your tps sensor. bogging in wot can be many things too. if youve already checked the voltage from the tps, how bout the map?
also if you have a vacuum gauge, you can check if a small vac leak is causing it. your not boosted are you? what does your idle vac readings say? wot vacuum readings?
bogging can occur due to fuel also. a very rich mixture in wot or part throttle will cause you to bog. im assuming you dont have a wideband to get the AF mixtures so, what you can do is have a friend follow behind you when you go into wot. if you have black smoke, pull the plugs to see if they are black.
a clogged fuel filter or injector will create bogging also. you can swap out the fuel filter to knock that out of the way. you can also use injector cleaner to see if that helps, or, swap out your injectors for a set of known working ones.
also, dont forget to check your throttle cable is good and working and check to see if the throttle body plate itself is opening properly.
Old 08-07-2005, 06:28 PM   #9
superbluecivicsi
AF - Advisor
i just noticed the mods in your sig.
im not really fimiliar with msd injectors but, are these peak n hold or saturated? cc?
you are using the b&m fpr? im assuming you have a fuel pressure guage to measure since you are changing fuel pressure settings. so where is your fuel pressure at in wot? idle? static?
also, im not familiar with the top speed cats, but, is this a hi flo cat or testpipe? a clogged cat will cause you to bog because it is restricting your exhaust system.
also you dont need the msd setup with your current setup. sell it and go pick up a vfac and dsm injectors
Old 08-11-2005, 04:50 PM   #10
whtteg
whtteg's Avatar
Originally Posted by superbluecivicsi
....also you dont need the msd setup with your current setup. sell it and go pick up a vfac and dsm injectors
I agree 100% ignition systems are a waste of money and time, not to mention that they are a real pain in the ass sometimes too.
Bookmarks
Google
Web AF
