No it wouldn't be the TPS sensor. The TPS sensor is only used to trigger open-loop mode, and adjust the transmission shifting patterns.
... Cam timing has a huge correlation on performance.
Guys, please try to troubleshoot in a logical pattern instead of random things that have no bearing on the possible problem.
The car runs horribly. The ignition timing was found to be at 45*. There was no maintinance done before, that would have advanced it 35*.
1) The two 12mm brass/aluminum stretch bolts that hold the dstributor on and set the timing are
NOT going to back themselves out by themselves.
2) The engine outputs rotate in a counter-clockwise fashion. If the distributor WAS loose, the timing would have been retarded from that motion, not advanced.
There-hence-forth, the timing can not be advanced, without some one advancing it. It should be obvious, that the ignition timing is not the problem.
The only other way the ignition timing can advance is if the valvetrain itself is advanced (The distributor is driven off the end of a camshaft). That can happen during valvetrain/timing belt installation, or the timing belt can slip on the valvetrain cogs. Since no maintenace was done. We are left with the timing belt having slipped.
That is how you troubleshoot in a logical manner. techspecs no offince, because we're all trying to help, but everything you've mentioned either has no bearing on the problem, or is incorrect.
Valve timing will run on one tooth slipped, most people never know the differance. By 3 teeth, most engines will run like complete crap.
FYI - The timing belt has slipped three, or four teeth.
At the very least replace the timing belt.
