coolant leakjon,123 07-27-2005, 07:02 PM just replaced the engine in my 93 toyota pickup, 3.0 with an manual tranny, have a coolant leak some where probaly just a hose loose some where, but it only leaks after i have parked and its has been sittin for about a half hour, that kind of has me baffled? any ideas KimMG 07-27-2005, 11:53 PM Where is it leaking from? Is there a puddle? Leaks can come from anywhere in the cooling system. Some autoparts stores rent or loan tools. See if you can get a cooling system pressure tester. It looks a little like a bicycle pump. Pressurize the system and see if you can find the leak. Look for water stains that may help to identify the leak. fourwd1 08-01-2005, 09:59 AM Pressurize the system and see if you can find the leak. Look for water stains that may help to identify the leak. 2 very good suggestions. Check around radiator and heater hose connections, all around the water pump, freeze plugs in the block, and with the 3.0 could even be a intake manifold gasket problem. Automotive Network, Inc., Copyright ©2012
