rear parking lights help?? '86 cressida
pgutierrez
07-27-2005, 02:13 AM
I need any info from someone who can help diagnos why the rear tail parking lights won't turn on when I flip on the parking lights. All other parking lights come on except the rear tails?? I am not familiar with this model (cressida) or non the fact Toyota...trying to help someone out. I found a small fuse box in the engine compartment and those were fine. Is there a seperate fuse box?? Any help would be graciously appreciated!!!
brucejunor
09-06-2005, 04:04 PM
I have a same problem. I need help. Did you get your problem solve? let me know.
rhandwor
10-17-2006, 02:55 PM
Check the bulbs then check connections for corrosion to the lights. Their should be a ground near by check this. If you have a 12v test light check for voltage. It may be a worn spot in the harness. To go much farther you will need a wiring diagram.
