Originally Posted by UPSPilot
I'm sorry to tell you that if your TB did not come with Fog lights then the factory lights will be a pain to install. You would have to fabricate the parts yourself to install. There are 2 different front bumpers for the TB one has the cut outs with the mountings for the fog lights. Also there is no plugs on the light harness to plug fog lights into. You will have to get a switch or purchase the factory Light/Fog switch then wire them into the low beam circuit.
Removed front cover and manufactured a L clamp with a metal bar and attched it to the impact bar. I saw in the Internet that there we're 2 types of Bumper Covers. I only need to re-adjust the right one. It toke me 3 hours to do the whole process. I will buy the harness at the GM Dealer and connect them to the low beam if the OEM Fog light switch does not connect to the main Light Switch. Do I need to install a Relay?
Thanks for your support. I think the hardest thing to do is to attach the to the impact bar. the rest I been used to it with my Ex Volvo 850 T5, and Hondas
Thanks,
Augie
