Originally Posted by rteal
I have a 1997 GMC Jimmy. A/C has been RECHARGED and added new freon. It still blows out warm air. What causes this? Could there be a bad switch or something causing it to go to the vents? Compressor kicks off & on allot. If so were could these sitches be loacted at on the Jimmy? Any help would be greatly appreciated. Thanks
You are still low on refrigerant.
Check the system pressure with the AC on MAX and the fan on full blast.
Also note, you don't just add refrigerant without knowing the system pressure. And remember you have to add oil too.
