A/C question
rum runner
07-25-2005, 07:45 AM
R134-A system
I guess this is the time of year for a/c questions, and I have one :)
I am not sure which approach to take on repairing my a/c unit. The a/c compressor ran in 4-5 second cycles and cooled ok, it operated that way for some time. Recently I turned on the a/c and it did not cool at all. The compressor still tries to operate in short cycles. Does this sound like a compressor on the way out or a need of freon? If it has leaked freon it got out within a 7 day period.........
Any help appreciated.
RR
lenjack
07-25-2005, 03:19 PM
I'm guessing here. Compressor is probably OK. System is likely overcharged or undercharged. Wait for input from others.
techspecs
07-28-2005, 11:14 PM
Are you saying that you had it charged and it stopped working 7 days later, or that it was 7 days between you noticing when it worked and when it stopped working? If it was just 7 days between working and not it could just be that the pressure finally dropped low enough and needs recharged and not necessarily a leak that all of a sudden dumped all your freon in 7 days.
rum runner
07-29-2005, 08:14 AM
It was 7 days between me noticing when it worked and when it stopped working. I did not know freon could escape so fast. Unit has probably been low for some time.
I will try the 134-a kits with a gage attached. Someone said the freon kits have good instructions inside.
Birmingham, Alabama :)
rum runner
07-29-2005, 05:58 PM
Your friendly Wal Mart store sells a R-134a kit with freon and a gauge. The can of freon has refrigerant, stop leak, oil charge, leak finder, o-ring conditioner. It says to connect to the low side of unit and hold the can upside down. It even shows a picture of it. Anyone agree with that process?
dinok
07-30-2005, 07:03 PM
Hello there,
I have had to recharg my Camry '94 AC unit few times this year and last time I put some sealant to it.
Usually I have had to refill once a month.
If you go to walmart or k-mart stores you can buy whole kit for about $30-$40, after that you can buy only a can of freon to recharge your unit if it leaks again.
Hope this help.
Dino K
