| Non Specific This is the forum to post and generalized racing questions. |
07-24-2005, 11:47 PM
Firebird Guy
Anyone pull a motor???
From the bottom????
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
07-24-2005, 11:49 PM
Re: Anyone pull a motor???
Nope...I've helped pull one from the top though.
07-24-2005, 11:55 PM
On Fire!
Oh you backwards man you...
I suspect it's easier to disassemble the whole front crossmember from the chassis than to try to shoehorn the motor outta it's little cubby hole.
Something to remember if I ever pull mine.
2008 Pontiac G8 GT - - - - - - - - +1 FTW!
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
I watched 3 of your runs and you were handling it man...On that 40 sec. run, I don't if you hit that cone or if it was jet wash...lol
07-25-2005, 12:45 AM
Oh yeah, we do that all the time where i work
07-25-2005, 02:52 AM
Now how do you get the engine out from under with the lift in the way?
07-25-2005, 03:15 AM
GM did not build 4th gen F-bodies with the do-it-yourselfer in mind.
07-25-2005, 07:40 AM
Re: Re: Anyone pull a motor???
curse you sticky that was my insightful comment!
yeah I saw on HP TV they were working on a mid 90's Camaro and they said GM designed these engines for the car to be lifted over it rather than the engine pulled....
2002 Acura RSX Type-S
Originally Posted by SiGNAL748
I have an outrageously large penis.
07-25-2005, 08:33 AM
I dont know what kind of lifts you guys use, i'm guessing four posts? But we use 2 post lifts with 4 arms that you put under the frame of the car. Very supportive, and much easier to use than 4 posts. We haven't had any LS1 engines that need pulling out, because well...that's just unheard of, an LS1 needing pulled out for failure reasons. But we've had to pull many Northstars out, and that's the ideal way to do it.
07-25-2005, 10:55 AM
Mr2 engines come out the bottom. What I did, is basically had the car on a lift, setup the hoist, dropped the engine on a crate, disconnected the hoist, and lifted the car up using the hoist.
2001 Honda S2000 New Formula Red
Mods:
Engine: Comptech Air Intake Box, miscellanous chrome dress up pieces
Suspension: Comptech front strut tower bar
Exterior: Grillcraft grill, lots of wax
Interior: Rick's leather console cover, Muz one-piece luxury floormats, Rick's windscreen,
Electronics/Audio: Polk speakers
Wheels/tires: 18" SSR Competition wheels with 225/40 and 255/35 tires
07-25-2005, 01:16 PM
Firebird Guy
Re: Re: Re: Anyone pull a motor???
Mine didn't fail.
We used the hoist to get the car up high enough. Rear tires are on ramps.
Once the car is up high enough, put jackstands under it, and let the hoist down. Pull the hoist outta the way.  Sounds kinda dangerous, but many have done it.
This is how I left it....since returned the hoist to its owner though.
This is an odd pic.....
Stock'ish'
07-25-2005, 01:22 PM
Re: Re: Re: Re: Anyone pull a motor???
Originally Posted by Mr. Luos
Mine didn't fail.
Keep us updated on the 406 install please, i wanna see that sucker in there...maybe even a video or short clips..
07-25-2005, 01:35 PM
Firebird Guy
402. Close enough though.
You know I will keep ya up-to-date.
Still a while away from being running again, but as soon as it is...I will have a video clip.
Stock'ish'
07-25-2005, 02:32 PM
boost in, apex seals out
a little ot, but how wide are you wheels (and what tire width)?
RX-7 TII
07-25-2005, 02:57 PM
Firebird Guy
Normally 275/40/17's.
Those are 245/45/17's. Burnout tires. They were just on the front since the DR's were on the rears when I swapped them out. Cheaper to just leave them on those rims for now. No sense in putting the wider ones back on quite yet....not like the car is going anywhere.
Stock'ish'
07-25-2005, 03:15 PM
Ah, how bout an instructional video!?
That would be so cool, AF's instructional video on R&R of an engine from an FBody. I know the removal part has already been done but i'm sure you could improvise somehow.
