95 s-10 Blazer Cruise Control Turned on by itself?
libra1996
07-24-2005, 06:29 PM
I was driving my truck and went from 30 to 75 mph by itself in a matter of seconds. I did not feel the gas pedal under my foot. It went down by itself. I tried to stop before I hit someone and the brakes just barely worked. I put it in park and it was still doing 75 and the rpm was in the red zone. felt like the cruise control was on, but it was not. it has done this several times. i took it to the shop and they could not find any problem, especially since there was no codes for the machine to pick up. I would like to disengage the cruise control to see if its that, but i have no handbook and the fuse box does not say which fuse is for cruise control. thanks for any input.
Cailen
07-24-2005, 10:02 PM
You put your truck in park while doing 75mph and your transmission didn't fall off on to the road?
BlazerLT
07-25-2005, 02:09 PM
sounds like a vacuum leak.
Check the brake booster hose.
redwheeler
07-25-2005, 09:08 PM
ive seen this lube all throttle cables and parts
Cailen
07-25-2005, 09:20 PM
agreed redwheeler
check to see that this sucker is lubed, and everything connected to it
http://i15.photobucket.com/albums/a358/Cailen/throttle.jpg
BlazerLT
07-25-2005, 09:38 PM
Also, remove the air intake and clean the throttle body butterfly.
wolfox
07-25-2005, 09:55 PM
Of note:
Never lubricate the cables themselves. Only the throttle linkage and the cam/springs on the side of the intake need a *light* coating of lube. Oil contaminated cables collect dirt internally over time and end up sticking or binding them. If the cables themselves are responsible for rough operation of the throttle, replace them.
